Looking for best Bilge Paint. Can you recommend?
If your looking for the best. A good 2 part epoxy as a base with Awlgrip as top coat Is tough to beat. Not a cheap combo though.
As in any paint job, the prep is 90 percent of job.
1 Post
black holds heat....
Sherwin Williams marine polyurethane coating..125 a gallon with a qt of hardener..the paint is like gelcoat and it will fill major voids..does not dull or yellow like rustolum..
Looking to do a few storage compartments , I looked up rusoleum and there are about 30 different products on there site here in the uk can anyone here show me the exact product I should use . Thanks
I use this http://www.rustoleum.com/product-cat...tective-enamel
I mix 3Qts white to 1qt beige (little less) to get that off white fiberglass color.
I've also never had a staining issue.
