why stainless steel rocker arms? >
Old 01-10-2016, 05:58 PM
Full Force's Avatar
hope so, I have them... lol
Originally Posted by mike tkach
i just want to say don,t be afraid of the scorpian endurance arms and all they make is made in the usa with american materials.i will spend a few xtra bucks to buy american made parts.
Full Force is offline
Old 01-10-2016, 07:02 PM
14 apache's Avatar
Originally Posted by GPM
Just curious, can anyone actually answer the posters question,
I don't know the reason but I think it might have to do with the heat treat process.
14 apache is offline
Old 01-10-2016, 07:15 PM
or the weight maybe
MILD THUNDER is offline
Old 01-10-2016, 07:28 PM
Steel rockers tend to be recommended for serious valve spring pressure where in open pressures are 800lbs and beyond .. I've ran crower on shaft set ups the went back to jesels for offsets at the push rod tip . Just strength for steel and stainless .. Trunion is still another conversation and most mfg will rebuild your rockers
cmattj is offline
Old 01-10-2016, 07:40 PM
Originally Posted by Cole2534
I was pondering this recently- why choose stainless steel for a rocker arm material and not another steel alloy like 4140?
I would think it's just an option for corrosion resistance. Under the valve covers is where you'll find any condensation, whether it's from a little reversion, or just a cold block and not enough oil temp. This time of year, every engine I dyno ends up with a little milky oil under the breathers, and bottom of the fill plug just from the air temp.
HaxbySpeed is offline
Old 01-10-2016, 08:39 PM
this would be a good question for a metallurgist. is it possible that it has to do with elasticity or some such thing? I would think that the metal used would need to have a minute amount of give in it vrs something super hard that would tend to crack over time.
compedgemarine is offline
Old 01-10-2016, 10:14 PM
GPM
I wish Dave Crower was still around, maybe he could tell us why they starting using stainless about 30 or so years ago.
GPM is offline
