Drilling holes in transom >
Old 03-07-2016, 11:18 PM
Originally Posted by jpf091959
We have a short boating season and I hate being down for repairs, so overkill everything. I have been told that this is ridiculous, but this is what I do, and I don't have leaks.
http://s1126.photobucket.com/user/jp...tml?sort=3&o=0
Lots of good ideas out there.
I thought abt doing this too. Seems like getting length of the pipe just right would be critical.
zz28zz is offline
Old 03-08-2016, 05:19 AM
If I was working with a foam transom this would be a must for mounting the transom assembly. Although I would use a heavier walled to get a larger footprint.
Black Baja is offline
Old 03-08-2016, 05:22 AM
You would want the tubing to be a little shorter than the transom. Then chamfer the transom holes to the tubing thickness. That way the tubing is locked in place.
Old 03-08-2016, 07:47 AM
I use 3M 5200 like many here below the water line. Never had an issue. I'd rather have some extra work replacing components in the future than replacing my transom...
BBCLiberator is offline
Old 03-08-2016, 05:36 PM
I know the 5200 will stick like crazy to clean gelcoat, but are there any issues with 5200 sticking to the epoxy? Will the epoxy need a couple of days to complete out-gassing (before applying sealant), or would overnight drying be fine?
zz28zz is offline
Old 03-08-2016, 08:38 PM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
Originally Posted by Black Baja
Drill oversize holes. Glass or epoxy the holes shut. Re-drill to bolt size and use life seal on the outside and inside.
I really like this idea! After just having a new transom put in my cat, I think I will go this route when I go to install my jackplate.
What is the general consensus on HOW MUCH BIGGER to drill the holes, and then fill?
Let's assume for this example: 5/8" diameter bolts.
Also, would you sleeve/collar the holes to avoid transom squish?
Sydwayz is offline
Old 03-08-2016, 08:46 PM
I think I would make stainless sleeves for the holes, regardless of how you penetrate the transom. I like drilling an oversize hole and filling it but would still use a stainless sleeve.
horsepower1 is offline
