is this a good cam/set up for my 454? >
Old 05-18-2016, 10:39 PM
The carb will work, but it's not optimal, the cam has to go, and if you want a performance cam, you need a better exhaust. Look for a used set of Gil's. They will be your best bang for your buck. Stainless Marine, Dana, EMI will also work if you find a good deal. Plan on $1000 for a good complete set. Others will have a better opinion on the cam, but first you need to find out what you have for heads.
endeavour32 is offline
Old 05-18-2016, 10:49 PM
Alright thanks guys. Tomorrows project will be figuring out what heads it has. I'm hoping I'm mistaken but pretty sure they just sucked at this build.
Fman is offline
Old 05-18-2016, 10:58 PM
Let this be a lesson to you//// JimBob's cousin Earl should not be building your motors in his shop, err woodshed no matter how good of a deal he gives you...
phragle is offline
Old 05-18-2016, 11:25 PM
Hahaha right. Glad it was the last owner who ate the bill on this one. Sadly I will be the one fixing the crap job. At least I will know it will be done right when it's finished. The worst part is a local marine/machine shop did the build. Guess who I'm not ever going to use.
Fman is offline
Old 05-18-2016, 11:36 PM
TomZ's Avatar
Received 1,231 Likes on 686 Posts
Are you positive that the info you gave on the cam is correct?
TomZ is offline
Old 05-19-2016, 12:11 AM
Quickest and cheapest way to be on the water next week would be to change the cam to something that will work with the stock exhaust and find a good used high rise dual plane intake. Use the carb and flamearrester you have. $500 bucks should do it. Go out and have fun this summer. Next winter take the engine completely down and see just what parts you do have.
picklenjim is offline
Old 05-19-2016, 12:55 AM
Originally Posted by endeavour32
No kidding- Everything is off. I sure hope they didn't put a rectangle intake on an oval port head. The kicker is the stock exhaust on this combo.
Believe it or not this used to be done quite often in the past. Supposedly made a lot of low end torque. Google up rectangular port intake with oval port heads and there are tons of testimonies.
Old 05-19-2016, 06:05 AM
I have yet to physically see the cam but that's the number listed after the camshaft on the parts sheet
Fman is offline
Old 05-19-2016, 06:06 AM
I think this will be my plan. Wife won't be happy if the first summer we have it it is just a paper weight.
Fman is offline
Old 05-19-2016, 06:30 AM
Any chance they put some higher compression pistons in it?
Lets say it was a 10:1 454, 850 double pumper , single plane edelbrock intake, 244/254 112 cam, it might not be totally horrible. I do agree though, that is alot of cam for a 454, unless of course, you were going to be spinning it fairly hard rpm wise. Def not 5k rpm max. is there any water in the oil from reversion? How did it run on the test ride?
MILD THUNDER is offline
