500EFI starts to fall flat after 2500rpm -Anybody?
clearly the drive level is the root of all your issue
OK Problem solved. I also bought the scan tool from Rinda and found that there was a code for map sensor which I replaced as well. From what I understand that the map sensor does, this could have been the problem all along, but the injectors certainly needing servicing!
http://www.offshoreonly.com/forums/g...7-4lx-mpi.html
