Mercruiser 502 mpi mag rich idle low vacuum new rebuild >
Old 07-07-2016, 11:18 PM
Default Mercruiser 502 mpi mag rich idle low vacuum new rebuild
I'm at wits end, just installed a rebuilt bored .30 over new pistons everything balanced pressure tested and professionally assembled engine. Compression tested at 150 psi, injectors rebuilt all new sensors except TPS and IAT sensor. The engine sounds great above idle with the exception of a light lifter tick. At idle it has an extremely rich fuel mixture with a very loopy idle for a stock 502. Seems to have very low intake vacuum at idle map sensor voltage is at 3.6 all other sensors look fine injector pulse width is at 3.9ms at idle. I tried changed MAP sensor with no positive results. I went as far as using the old map sensor plugged into the harness with a vacuum pump and drew the voltage down to 1.6 with smoothed out idle and reduced injector pulse width to 2.1ms. I then capped all vacuum ports to the intake manifold to make sure there were no intake leaks, Base timing was set at 8 degrees BTC with a roll back snap on timing light with the ecm in base timing moded.Also I checked the thottle body to make sure that the cable was not holding the butterfly open.
Tidewater757 is offline
Old 07-08-2016, 01:49 PM
Received 1,811 Likes on 901 Posts
Is it possible the timing chain set was not installed correctly?? Maybe off a tooth??
Griff is offline
Old 07-08-2016, 02:13 PM
I spoke with the engine builder this morning and he is 100% sure the timing is correct. I got a new manual vacuum gauge today and it is reading on 7 in and what I am reading it should be somewhere around 14 in.
Old 07-08-2016, 02:16 PM
I also swapped the throttle body with the good running port engine and acts the same.
Old 07-08-2016, 02:36 PM
SB
Received 3,102 Likes on 1,398 Posts
7 "Hg vacuum at idle :
Very large camshaft
or
valves or pistons not sealing
or
worn cam (is it a flat tappet or HR) - if FT I would check to see if worn.
or
ignition timing is fubar
SB is offline
Old 07-08-2016, 02:41 PM
Not a large cam shaft....stock 502 420hp
New engine so I hope it isn't a sealing problem....
Machine shop said the cam was in good shape
ignition timing is 8 degrees before top dead center base
Old 07-08-2016, 02:49 PM
Charter Member #1171
obnoxus's Avatar
New engine, old cam??
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 07-08-2016, 02:50 PM
Yes
Old 07-08-2016, 10:55 PM
Was this your original block and heads? If so what was the cause for a rebuild if any?
ThGdThBdThUgly is offline
Old 07-09-2016, 09:17 AM
Location: Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
That is why I always use a degree wheel when installing cam's to make sure its 100% correct. In my younger days I installed a cam one tooth off. Low vacuum and fell on it's face trying to get on plane. Sounded great on the trailer....
1BIGJIM is offline
