Target Air Fuel ration N/A engines.?
#131
We shut the port engine down and idled the last short distance to the dock. Per the engine builders request, we pulled the #3 & #6 plug and sent him a picture of each plug. His comment was they were perfect. Also we have zero soot on the transom. Much of the credit goes to the 1150 CFM Holley Marine Dominators. We quit bothering with the AFR meter as these carbs are spot on out of the box. We now also just touch the key to fire the engines and we can now idle at less that 500 RPM in gear. Docking is easy without stalling and not touching the throttles. Not bad for 500 ci 9.5 to motors making 780 HP. Only took us 20 yrs to find the right high HP combination that works in a pleasure boat.
#132
I thought you where using the newer Ultra Dominators Gen 3's ?
Are they the 2 circuit 0-80905HB ?
https://www.holley.com/products/fuel...arts/0-80905HB
#133
Here are the carbs we are using and they were purchased at Jeg's in 2013. These carbs were not officially "Marine USCG" but we did buy and install the Holley J-tubes. I kind of lost the end of the string on some the newer Holley nomenclature and offerings.
Gen 3 Ultra Dominator 4500 Series Carburetor
1150CFM
2-Circuit
1 x 4 Carb Set-Ups
1.830" Venturii
2.00" Throttle Bore
Black
http://www.jegs.com/i/Holley/510/0-80905BK/10002/-1
1150CFM
2-Circuit
1 x 4 Carb Set-Ups
1.830" Venturii
2.00" Throttle Bore
Black
#134
6800 rpm, 500 ci w/3.75" stroke. Similar to the APBA Super Cat engines. The bore/stroke ratios are the same as the SBC. The HP is limited by the 9.5 to CR but they run great on premium pump gas.
#135
Geronimo36
Hard to tell from the pic. There should be a heat mark on the grounding strap which I cant see. Would need to see how far back the heat mark is from the tip.
#136
Geronimo36
For me cruise RPM is anywhere between 3300-3800. 3300 is low 50's and 3800 is 62-64mph depending on fuel load.
I don't cruise at 4K+ because I start seeing boost right around there. 3800 is around zero and the boat is running a good number. Above that and into boost (1-3 psi), it starts sucking down fuel and for me it's not worth cruising at 4K+.
#137
I've always tried to be just up from the bend. I was looking for as well to see how timing was but looks like new plugs and probably 32 deg of timing or less if I had to guess but is difficult to see from angle of pic.
#138
