Target Air Fuel ration N/A engines.?
Here is my chart right from my ecm (as target AFR) KPA on the left and rpm across the bottom. Anything over 105kpa and I'm making boost. This is on a twin turbo GM ls but you can atleast see where I'm sitting before boost comes on.
I usally like to have idle around 13.5-14 this motor loved 13.5. at 14 it would want to "hunt"
Should add spent many late nights running it in each area shutting it off and check plugs. I just pulled the heads off (to add studs) and no sign of detonation with these afr. I was a little worried about my cruise (3000rpm) afr but once I got knock sensor dialed in I still had plenty of timing left before it started binging.
Geronimo36
Ok, My gut tells me a good target Air fuel in the boat is 12-12.4:1, is that what you guys shoot for? I dynode and had engines at low 12's, in boat I see low 11's and sometimes 10.8 for a short burst, I am going to re jet for low 12's "in boat" I have widebands so I can keep eye on it all the time, is that the best target A/F?
