Russell Check Valve VS. Anti-Siphon Valve
if your pickups are some where that you can get to them with out opening the engine hatch then you can put a shut off valve on them. the anti siphon is so if the fuel line fails it will not leak into the engine room if there is a fire but if you can shut the fuel off with out opening the hatch it will pass coast guard requirements.
