Reoccurung water pump failures...
#41
#42
#43
https://www.gcsmarine.com/content/impellers/impellers
maybe this would at least help you to identify the location of the cause without having to stop and change out another impellor
#44
Dont ever take anything for granted .... the dealer tech could have Efed up because his IPhone rang or some **** . Ive literally strapped the boat down on the trailer ,and backed into the water almost over the transom , to find air leaks (water) . Pull the inlet hose off your pump and back into water , the water should flow freely out of the hose .
If not, you have a blockage . Ive seen the Hose from the Transom to the Pump collapse , because the outer hose was kinked .
#47
Well, I don't think that is the issue because of the inconsistency and the fact that a fresh impeller picks up water properly when nothing else has changed.
But, enough experienced advice is saying to change that hose, what can I lose, minor expense and some time.
I assume the hose can be changed without removing the drive, would that be correct???
#48
#49
could be, but I went thru the menu on your link and says B3 product not available
#50
