What are you guys using for water PSI and vacuum line?
Rigging the boat and I'm wondering what guys are doing for mechanical water pressure and vacuum hose.
I believe the autometer gauges I have come with 1/8"NPT male fittings. My water "tap" on the intake is a -3AN male (it's welded in).
My vacuum port on the manifold is 1/8"NPT female.
Polyethylene tubing and brass compression fittings?
Thanks,
Rob
Thanks,
Rob
Charter Member#568
Brass compression for the vacuum on mine. The gauge fitting pretty much dictated the size for the pressure lines.
Straight bottoms and flat decks
I bought other 1/8 line and ended up replacing it with this due to better durability. (oil pressure)
http://www.mcmaster.com/#catalog/122/141/=143ojfd
(9685T1)
The long nuts are better
http://www.mcmaster.com/#catalog/122/177/=143okdd
1/8" 1/2" 0.030" 50915K101
All my other mechanical gauges are rubber hose (like above) which holds up just fine too
(9685T1)
My boat has 1/8" poly tubing for water psi with brass compression fittings. Never had an issue or leak.
I replaced the water psi line on my Pantera with 1/8" poly tubing as well. You just have to be very careful not let it get kinked when you are running it up to the dash.
Charter Member#568
The only line I'm running the brass compression fittings on is vacuum. Never a leak from any of them. I'm actually not sure what the other fittings are offhand. Likely AN
I ended up doing things twice when the poly I bought from Carr was too soft (Durometer 55D) and the brass ferule would damage the connection ends.
The one I listed above is much harder and durable, (Hard (Rockwell R110)) less likely to kink but not as hard as the 10' that comes with gauges originally. That doesn`t come back from a kink as easily.
Charter Member#568
