The curse continues... Brand new coupler slipping?
#41
I have had that happen before when doing alignments. Just for the hell of it, put the alignment tool in and hit it with a rubber mallet side to side and top and bottom. Sometimes the rubber can take a set and needs a little help to center itself. Give it a few good whacks.
Steve
Steve
#42
Wish that would have worked... believe me I tried everything. Looking down through the bearing you could watch the coupler make a wobbling spiral.... definitely bad.
#43
#44
It was a proper test based on the circumstances. The coupler was already screwed. If you had seen the wobble while turning over the engine, you'd understand.
#47
Tom, are you using the tapered centering screws for install alignment? here is a Service Bulletin for install. Your journey is starting to sound like Scott Jourgensen's luck.
All the best.
http://www.marinemechanic.com/merc/d...ange_EN_11.pdf
All the best.
#49
Just an update... and it's a good one!
Got a replacement coupler from Sick Stinger (many thanks Mike!) as well as a new replacement from Amazon/Sierra (that was a surprise!). I installed the original flywheel (had a new ring put on it), aligned the coupler to the flywheel, installed everything in the boat, got her perfectly aligned, and I'm happy to say that the set-up has about six hours on the clock with no drive issues. In fact, I've used the boat more in the last two weeks than I had the entire summer combined!
Just want to say thanks to everyone for all the help! And a huge thanks to Sick Stinger for standing behind his parts! That's huge in my book.
