Winterizing?
I drain my blocks by pulling my block plugs, crimp off my crossover bypass then I feed 5 gallons of RV antifreeze through them. I have 4-3/16" holes in my thermostats. Exhaust is pink after about 4.5 gallons.
same as above,but I use -100° boiler antifreeze,I get it at the plumbing supply house.If you look at the dilution rates of the rv stuff,,it doesn't take to much water to make it freeze up.stuff I use will still be slushy at -20°.
I suck up 4 gallons 50/50 then remove water pump hose drain most water out put hose back on then pull thermostat cover fill with 100% green after the 100 % I top off 50/50 till full.
No think he means the stuff fish don't like!
Some people won't use rv antifreeze because they say it don't work well. I use rv and never had a issue and I have done plenty of water systems with out a failure. Just can't mix it with water. I think using green is horable knowing there is non toxic stuff to use that works.
