Hard start 540 whipplecharged
I don't think that's what the problem would be, these motors are multi port injected below the intercooler so getting fuel down there should be instantaneous upon cranking. (unless) - I think it's what Teague is saying - must be an issue with air pockets in the rail / regulator.
A picture would solve most of these questions. Whipple's are generally rear-port injected, but they do make a port injected intake now as well. The general consensus is that with the rear mount injectors, the fuel has to travel further on initial start up like Haxby said. This is common with everyone I know running a Whipple.
Yes, I'm old enough to say I worked on newer vehicles that many had a cold start injector. Sounds like what these needed.
Well as long as I'm not the only one I'm not that worried anymore ! I'm still going to look into it and do some more diagnosing in the spring time as she's winterized and in the barn for the winter.
Could be a leaking injector which could let fuel siphon back to the tank, letting air into the fuel rail. Whipple recommends removing the spring check (antisiphon) valve at the tank to improve fuel flow. If you get a leak at a higher point (like an injector), then fuel in the rail and lines could siphon back, causing an air pocket in the fuel system. Since most setups do not have a return to the tank, this air can only be purged thru the injectors, and the injectors have to be opening (during cranking) to get the air purged out. Only running the fuel pump will not purge this air like it would in a return to tank system would.
