Anyone know these shifters?
"Unregistered Gun"
Recently purchased a 1996 Top Gun and trying to figure out the brand of shifter/throttles these are. I have a issue with the starboard throttle being hard to push the throttle from 1/2 position to wot, from idle to 1/2 throttle it slides fine. Still need to troubleshoot and see if it could be the cable or carb, but it feels more like the shifter needs adjusted so anyone have any experience with these?
Thanks!!
Thanks!!
probably cable , disconnect cable from throttle and carb . Check the throttle first , if its good pull the cable buy hand , shouldnt be any tight spots or binding.
"Unregistered Gun"
Hey Jimmy. You might get away with just lubing it. Here are a couple of methods. There are videos out there too.
http://www.boatus.com/magazine/trail...rol-cables.asp
http://goldwingdocs.com/forum/viewtopic.php?t=13272
http://www.triumphrat.net/air-cooled...tle-cable.html
they look like older latham controls ..... you probably have a bad cable... i have these 4 sale if you have to replace 1. http://www.offshoreonly.com/forums/s...les-shift.html
"Unregistered Gun"
Thanks guys, looks like it is the cable. Still trying to figure out exactly what brand of controls these are. I pulled the throttles today to check the cables and couldn't find any info stamped on them, they're pretty simple units and I didn't notice any adjustment for the resistance of the lever.
