Battery boxes >
Battery boxes
Battery boxes
Old 12-09-2016, 07:24 PM
vintage chromoly's Avatar
Thanks for all the ideas fellas.
Much appreciated!
vintage chromoly is offline
Old 12-12-2016, 04:50 PM
Originally Posted by 272lsformula
How well do the bottom clamp plates work in a marine environment? I like the look, and if they work well, it may allow me to tuck my batteries under the cockpit sole in front of my engines, as there is a hidden area there but its a little limited height wise.
murfman is offline
Old 12-13-2016, 02:23 PM
I won't buy boat battery boxes again that don't have top step plate. Never had them till now, and it is WAY nicer when stepping around in the bilge.
ALL_IN! is offline
Old 12-13-2016, 05:06 PM
Received 4,383 Likes on 1,252 Posts
If you get the Optima specific boxes then you`re always stuck with those batteries. never had any luck with any of them, red, yellow, blue. junk
ICDEDPPL is offline
Old 12-14-2016, 08:14 AM
Originally Posted by vintage chromoly
Hello all.
What is everyone using for battery boxes?
I have optima batteries.
Depending on what series of Optima. I have a set I got from Mystic a while back. Used bottoms with new polished tops. I need a pic of the battery series you are running. They did not fit the orpimas I have and i can get them to you cheap!!
mcprodesign is offline
Old 12-14-2016, 08:22 AM
I have had blue tops in all my boats. They have never failed and I am on 6 years ( or more) on the set I have. Am I just lucky? They were almost dead and in my boat when I go tit.. ( got tit typo lol) anyway. They are not huge amps but still working. Maybe about 75 percent of new. But like I said . Still working. The only time I need all the amps to have full power from my stereo is when i am under way.(Then Both my alternators make up for any battery il performance ). Maybe I am missing some performance . But like i said . They have never failed me.
I think they changed manufacturing plants in the last 5 years or so.. Maybe they are not as good as the old blue ones I have.. But like I said . I have had nothing but good lick and durability with my batteries. I charge them once in a while in the winter only.. At about 2 amps.. My stereo memory was a slow drain so I now has a master throw.. They still keep a charge for Months and Months with no activity
Old 12-14-2016, 08:28 AM
I've had good luck with mine as well.
Any battery will underperform if not maintained.
Pm sent MC.
Old 12-14-2016, 09:21 AM
F-2 Speedy's Avatar
Received 3,079 Likes on 1,364 Posts
not sure what brand mine are, I'll check
F-2 Speedy is online now
Old 12-14-2016, 09:25 AM
Those are optima blue top, group 34
Old 12-14-2016, 10:03 AM
[ATTACH=CONFIG]562677[/ATTACH]
