Spark Plugs 496HO >
Spark Plugs 496HO
Spark Plugs 496HO
Old 01-29-2017, 08:04 PM
Default Spark Plugs 496HO
Anyone know what the difference between AC 41-983 vs 41-993
class6 is offline
Old 01-29-2017, 08:17 PM
SB
Received 3,115 Likes on 1,402 Posts
983's are Double Platinum
993's are Iridium
SB is offline
Old 01-29-2017, 10:33 PM
I have both here. What would you use in a 496 ho
class6 is offline
Old 01-30-2017, 07:20 PM
41-983
Ryan00TJ is offline
Old 01-30-2017, 07:53 PM
SB
Yup, if I'm reading this bulletin correctly, the 983's.
http://www.crowleymarine.com/sb/2/13078
SB is offline
Old 01-30-2017, 10:07 PM
BUP
NGK's do not touch the gap leave it alone.
If I recall correctly on the app of NGK's TR55IX ----- 7164
BUP is offline
Old 01-30-2017, 10:47 PM
SB
BUP, slight derail...kind of.....I'm not sure if you have ever used these, but they are great if you do have to gap a finewire type plug.
Photo is just one companies,,,a few other companies make the same thing. Can be found under search of 'Billet Spark Plug Gapper'
SB is offline
Old 01-31-2017, 02:00 AM
BUP
I like that tool but will add --- on double platinum tip spark plugs - (on the tip and the bottom side of the electrode ) you do not touch the gap because you off center the tips that causes misfires. Actually Mercruiser has a video all about that one as well. Thanks for the pics of the tool
BUP is offline
Old 01-31-2017, 02:03 AM
BUP
How does that tool open up the gap ? I see how easily it can close up a gap but does it have a slot the electrode goes into then turn the knob screw counter clockwise to open up the gap ?
BUP is offline
Old 01-31-2017, 02:09 AM
BUP
here is what I am talking about in a pic to help understand about gapping the plugs in which can off center the platinum discs, The off center causes misfires. Plus with double platinum tip spark plugs - opening up the gap can ruin the platinum disc on the under side of the electrode depending how or what gap tool is used.
http://shop.advanceautoparts.com/wcs...tinum-plug.jpg
BUP is offline
