Duel Side by side gas tanks-fill? >
Old 03-25-2017, 10:55 AM
Default Duel Side by side gas tanks-fill?
Just purchased 33 Active Thunder with dual gas tanks. Was wondering how do you keep them equal? Does one engine draw from one and the other engine draw from the other? It does have two fills on the outside. Coming off 30 Baja with one tank.
Any information welcomed.
Jeff
Lake Bound is offline
Old 03-25-2017, 10:59 AM
Not an AT but my 35 fountain with 2 tanks has 1 engine runnng off each. I'm going to add a crossover controlled with a valve just in case it's ever needed.
Crude Intentions is offline
Old 03-25-2017, 02:37 PM
Jeff
I would think that each engine on its own tank should stay pretty close. A crossover from tank to tank at the bottom would keep them level but I think that would be very unsafe ! I have two tanks two fills and one engine a real pain in the ass.
fbc25el is offline
Old 03-25-2017, 07:43 PM
I have the same thing in my Biesemeyer. Both lines go to shut offs and then Y into a filter and then a single line to a fuel pump... I also have a gas gauge with a switch under it that lets me flip from tank to tank. Sometimes they draw even sometime not. How about yours?
f_inscreenname is offline
Old 03-25-2017, 08:04 PM
Received 1,821 Likes on 907 Posts
Each engine has its own tank.
Griff is offline
Old 03-26-2017, 01:49 AM
I have zero experience with the issue, but have read quite often of one motor consuming more fuel than the other for no good reason at all.
Baja Rooster is offline
Old 03-26-2017, 04:50 AM
In my fountain one engine is alittle more thirsty than the other. Identical air fuel ratio as the other.
indysupra is offline
Old 03-26-2017, 08:26 AM
I have the same set up with the two shut off valves and a y into one line. They may or may not draw evenly it just depends what day it is. I do have return lines going back to the tanks where I can pull fuel from one tank and fill the other.
fbc25el is offline
