Low compression cylinder 7 and 8/ blowing smoke out of valvecovers
Unfortunately you don't have a choice.
Is it a remote possibility you had a little reversion prior to sitting for 7 months? That makes a little sense. I like your Lucas idea especially after inspection. Every once in a blue moon we can get lucky.
Exactly the end goal here. I know that using additives for say radiator stop leak and what not is just a waist of time but if I pulled the motor apart to find a stuck ring then I'd be kicking myself in the ass for no at least trying this stuff first.
I need to get my CMI headers pressure tested before I put this thing in the water also. Like you said if water did get in there that could be an issue.
yeap...never seen compression in a can really cure much !
