383 Carb Questions >
383 Carb Questions
383 Carb Questions
Old 05-02-2017, 08:20 AM
Default 383 Carb Questions
Ok so I'm new here, first post. Quick question.....am I nuts? Is there no clear place to get carb size requirements? Seems like every calculator I use gives me a different answer. I'm having a 383 built that's turning about 425hp and 450ft torque. The builder said a 750 eldebrock right out of the box would be fine. Not a fan. So I was thinking of going with a Holley 770 Marine Avenger, or a AED 750 http://www.aedperformance.com/compon...product_id,63/
However when I use carb calculators it's telling me I need 650cfm. So what's the deal? Can anybody shed some light on this. Sorry I know this is probably a total newb question.
Maveric2112 is offline
Old 05-02-2017, 08:51 AM
SB
Received 3,116 Likes on 1,403 Posts
Don't sweat the carb calculators.
You are correct. Dual plane intake def go with 750.
SB is offline
Old 05-04-2017, 07:57 PM
SB is wise...I tried to use the "correct" CFM in my 383. I bought a Quickfuel 750 last month. Can't wait to run it.
NHGuy is offline
Old 05-05-2017, 05:55 PM
GPM
My brother has been running the Edelbrock 750 marine carb on his 383 for years without a single problem, http://www.edelbrock.com/automotive/...s/marine.shtml
GPM is offline
Old 05-06-2017, 07:43 AM
For not super H/P setups the edelbrocks do work very well, and the elect choke setups are great(they do not like to start with a choke) never seen a 750vs750 test but would love to see that. Mopars back in the day make great HP with AFB's which is what edelbrocks are nowdays
ezstriper is offline
Old 05-06-2017, 08:24 AM
the carb calculator is probably for street engines. you put your Camaro with 425 hp 383 at full throttle. inside of 5 seconds you are breaking every speed limit in the land. then you and your car spend 90% of the time at 10 to 25% throttle. a boat is closer to a big truck than a high perf car as far as the way the engine is run.
dereknkathy is offline
