Timing curve for superchargers
Personally I wouldn't go more than 30-32 to start and gradually make changes. Nice you went with the Daytonas. Lots of flexibility. I'd think you'd want a short curve with an initial around 20. PM mild thunder and see what he ended up doing. He's got 420 MB's with Daytona ign also. How much boost you plan on running?
I'm not familiar with the daytonas as of yet however will be soon. Are you able to set the start/crank timing also? Btw Id initially aim for 6psi with 9.25:1. Maybe a little conservative but better than the alternative.
Although come to think of it icdpple on here was running same blowers with chillers if I recall at 9:1 static and seems like he was throwing 8 or 9 pds of boost at them. You could do a search on his 548's and see the details to be certin.
You are right in the ballpark, 28to 30 degrees with an afr of 11.8 to 12 @ wot.With a 9 to 1 motor your effective comp ratio is 13:1 with 8 lbs of boost. you better be running race fuel.
