Like Tree0Likes
Motor won't turn over 496ho
Old 05-29-2017, 02:47 PM
Default Motor won't turn over 496ho
Just had my boat worked on and running took it out on the lake and in 30min boat shuts off and won't turn over.
Turn key and I get a beep and power to all gauges, when I go to turn the key to start the engine I had someone Liston to the starter relay and it does click.
What's next down the line to look for?
Starter does not make a single noise
Snobo4rder08 is offline
Old 05-29-2017, 02:54 PM
My Boats: 1967 34 Hatteras summer house. 2000 Crownline 248ccr her boat. 79 Pantera 24 Sport.
probably that relay. jump across the 2 big terminals on top of it.
dereknkathy is offline
Old 05-30-2017, 11:50 AM
coolrunning racing
mrv8outboard's Avatar
My Boats: built myself 1994
Did the engine shut down on it's own? Did you shut it off and it will not crank? If you shut it off and when you went to restart it would not crank but heard just a click from the relay, just hold the key switch in the crank position and whack the starter motor with a piece if 2x4 or rubber dead blow hammer. Now if it just died and won't crank you may have an engine or drive failure.
mrv8outboard is offline
Old 05-30-2017, 12:40 PM
SB
Trade Score: (1)
IMHO Should have kept this on your current thread:
496ho shutting off
SB is offline
Old 05-30-2017, 06:22 PM
My Boats: 353 Formula Fastech
What was your battery voltage gauge at? Did they replace any of the batteries? Since the initial fix was thought to be mis-wired batteries and a non-working alternator. I am thinking you have more electrical problems then what were fixed. I believe some relays were replaced as well? Do you know which ones?
Questofpower is offline
