Best Way to Remove Foam Around Gas Tank
the problem is timing. you either spend the boating weekends cutting out the floor, gouging out the foam, etc,etc, or you find room for a 20 gallon moeller plastic tank for the next 2 months. mebbe in the cuddy? yeah it is kinda half-a$$ed but you have all fall to gut the cockpit and replace the tank. where do you run this guy? del river or margate-ocean city? in vintage chromo's resto thread for his pantera, on page 5 there is a bit about his fuel tank replacement. if these boats are that similar, they may all take essentially the same tank. at one point I stumbled across his tank measurements in his photobucket file. don't see it now, but he can probably find it for you. but 1 pic on page 5 shows the florida marine sticker which implies it is a standard tank they have on file. worth looking into. big fun. good luck. Derek.
I seem to remember a thread where someone used a kitchen electric carving knife to cut foam around a tank.
https://www.walmart.com/ip/Black-And...&wl13=&veh=sem
Padraig
Padraig
You didn't create a problem but you discovered one. You should be able to go ape with a fish tape and not puncture it so was ready to leak if not already. To be honest I was expecting a better story like using 3" lag bolts while mounting avtransducer to the bottom side of the hull. That would've been my style of mistake.
I thought that was a tube that was glassed in below the tank. unless on the vector it just opens to a void below the tank which lets tank get wet. if that is the case, put a tube in there before reinstalling the tank. this takes you right to the page in Vchromo's thread with the tank and hole it lives in. http://www.offshoreonly.com/forums/p...#&gid=1&pid=16 cuz the whole idea is to keep water and other stuff away from the bottom of the tank.
I used a piece of 1-1/4" Copper tube cut about 4-5" slit and open up like a U .
I would think twice about using electric powered anything to remove gas soaked foam.
For sure glass a new pvc tube in to keep water from contacting tank,i also sealed top of foam with epoxy resin per the advice of a local fibreglass guy.
The original tank in my Python was short and wider than the engine stringers.
Newer boats may have long narrow tanks like a Pantera.
