540 whipplecharged stalls coming off plane
have a 540 whipplecharged BBC. Runs absolutly great, for some reason this year it started stalling when you would come off plane. Pulling back on throttle easy, around 800-1300 rpm that's when it dies. It gives alittle spit or pop, like a misfire out the intake. Not sure if it's a fuel pressure issue, IAC , throttle blades not open enough??? Spark arrester blades are clean, IAC filter is clean. I have 28-30psi fuel pressure at idle and WOT. Aeromotive 1000 pump. After a stall it does re start right back up, no issues. Just not a good feeling when it stalls off plane. Any suggestions would be greatful, I'll be calling my engine builder on the weekend.
Thanks jason-
Thanks jason-
So, don't run it again until you get word on what fuel psi is supposed to be. Lean is mean, puts a torch on the pistons and likes to rattle things.
Your builder only works on week-ends ?
