Input shaft for new style (sloped) Bravo X same as XR or different?
Getting a newer X drive that is missing input shaft and ujoint,,was told its different than standard bravo.. Will xr fit or the X different from that as well.. also can u-joint be replaced? Does it use different gimble bearing or is there an adapter shaft to go from an x/xr drive to a bravo 1 gimble bearing? Thanks!
Just get the X/XR input shaft assy....you'll want the red dot or white dot gimbal bearing
