Daytona Sensors starter issues
I think I just realized the retard feature was turned off on my boxes. I should be ok now. Too much timing at start up I believe was causing the kick back. They have great features with those ignition system s. Stupid me confused on all the dials that control that issue. Otherwise I would have to use kill switches to turn over then light it like the race car guys etc.... Friggin A. Thanks for all the help.
The "anti-stall" curve, has 22 deg of base timing at idle , or should I say "SHOULD have", if you want your total timing to be 34*. if 36* total is what you want, then you would have 24* at idle. Anti-stall and Idle stabilization, are not the same thing. Idle stabilization, is a parameter that must be selected and setup thru the software.
These boxes are great, but reading the instructions that came with them, is mandatory.
Charter Member#568
Once you guys with this issue verify you're using the correct rotor for your application I'd disable the multi spark feature.
Straight bottoms and flat decks
The only way to have "start retard" is if using a custom timing mode uploaded from a PC/laptop. There is no "switch" to turn it on or off on the box.
Charter Member#568
Also, if you've activated the idle stabilization feature make sure you set it up so it's not activating during cranking. One of the parameters is how many signals to ignore during initial cranking.
