What can make 500 EFI shoot oil out the  dipstick tube? >
Old 04-10-2017, 08:23 PM
GNJ
GNJ's Avatar
Default What can make 500 EFI shoot oil out the dipstick tube?
Refreshed both motors over the winter - top ends done on both motors.
Mobil 15-50w oil
Mobil 1 oil filters
Port engine oil pressure gauge reading 60psi at idle, starboard reading 40psi at idle. Launched boat and ran at 3300-3500 rpm for about 5-10 mins. Powered up to 4500 - 4700 rpm and then smelled oil. Gauge on port motor was pegged at 80psi! Other motor normal at 50psi. Stopped, open hatch, saw about 4 ounces of oil had spewed out of diptick tube all over front of engine.
The only thing I can think of right now is changing the oil filter bypass valve in the block (GM 25161284) I ruined the old one taking it out.
Anybody have any thoughts?
GNJ is offline
Old 04-10-2017, 08:29 PM
Sounds like you have some crank pressure coming from somewhere in the motor that's cause it to puke.
Bajajay98 is offline
It is not an oil pressure problem, It is a crankcase pressure problem. Might just be because the rings aren't seated yet. Possible broken ring or the crankcase not properly vented.
snapmorgan is offline
Old 04-10-2017, 08:48 PM
jeff32's Avatar
compression checked?
jeff32 is offline
Old 04-10-2017, 08:50 PM
or maybe detonation bad enough to damage the ring lands.
mike tkach is offline
Old 04-11-2017, 05:28 AM
articfriends's Avatar
Bad injector melted a piston already? Usually something like that when you have severe blowby
articfriends is offline
Old 04-11-2017, 06:40 AM
SB
Received 3,116 Likes on 1,403 Posts
Just to make sure on the same page, last fall you indicated you only had 80hrs on the motors. Why the rebuilds again ? IE: What happened ?
For those who didn't see or remember this (like me) here is a thread he posted last fall with driveability issues and what performance parts are in these motors:
http://www.offshoreonly.com/forums/g...0efi-help.html
SB is offline
Old 04-11-2017, 07:01 AM
GNJ
GNJ's Avatar
SB - Headers leaked and heads had to be refreshed.
GNJ is offline
Old 04-11-2017, 07:05 AM
GNJ
GNJ's Avatar
Jeff32 - 120-125 on all 8. Leak down all around 10%
GNJ is offline
Old 04-11-2017, 07:08 AM
Is that cold? Sounds a little low for 500's
Unlimited jd is offline
