Mesa Balancing Racing Engines Our cylinder heads From the Inside Out
#31
P.S. This has been done for years to achieve what you want in the valve and spring assembly,but when you want a quality piece you measure and use what you need the first time therefore giving the customer what he deserves a top quality component. Thanks for the reply Laz
#33
Ok that's a great question the distance is not always longer but in most cases in the aftermarket heads it is and yes the standard of the industry is were it all started from the standard GM valve length. As you can see valve trane problems are easy to solve especially if you start from the beginning from the seat of the valve up towards the rocker.
#34
Laz, thanks for all adding some gearhead porn! It's always great to have a major player participate here. It lets the shade tree hacks as myself understand how we have been doing everything wrong.
#35
We don't come here to get along, we're here to be entertained! Thanks for leaving us dad, you said that you were just going out for a pack of smokes,,,lol
#36
Finished porting the first set of heads today and wanted to show some new pics before we send to hard coat anodize tomorrow. Please note all intake as well as exhaust guides are removed for the porting work to be able to reach the guide bosses without grinding the guides and for the most room possible to work. It's more work but leaves a better finished final product.
Finished chambers for volume and shape
Finished intake ports for cross sectional size and port volume
Finished exhaust port
#38
