Engine Stands for deep oil pans >
Old 09-11-2017, 04:32 AM
Rhythm and Blues's Avatar
Default Engine Stands for deep oil pans
Good morning, would anyone know of a set of these tow piece engine stands that will clear a deep 14qt oil pan? I don't mean width wise, I know they clear on the sides but rather leg length wise; in other words a set that the legs will touch the ground before the bottom of the pan? Thanks. JEGS Performance Products 80063: Two Piece Engine Storage Stand for Small Block and Big Block Chevrolet Engine | JEGS
Rhythm and Blues is offline
Old 09-11-2017, 08:45 AM
Were doomed!
Wally's Avatar
if it doesn't clear as is then install bigger casters on it
-Wally
Wally is offline
Old 09-11-2017, 03:03 PM
Yeah, thats a consideration I thought of but rather than shooting from the hip I want to know if anyone has seen ones designed to work work with deep pan..?
Old 09-11-2017, 03:36 PM
F-2 Speedy's Avatar
Received 3,047 Likes on 1,357 Posts
you can find them, but there more than 69 bucks
Heavy Duty, BBC, SBC, Big Block, Small Block Engine Cradles, Stand, GM, Chevy | eBay
F-2 Speedy is offline
Old 09-11-2017, 04:16 PM
the stock pan hangs down about 1/2 inch below the bottom of the frame. Jegs sez it is flush with rail but pic sez otherwise. so you have room for 3 to 4 inches more of pan before getting close to the floor. and it looks like you can shim the casters up another 3/4 inch. so how much deeper than stock is your pan? I would also cut a piece of 2 by 4 and place it between top of rail and bottom of block where flywheel is to keep it from sagging...like the heavy duty ebay one did. I love it when I get these brilliant ideas and see everyone else had it too.
dereknkathy is offline
Old 09-11-2017, 05:04 PM
I've seen those too, not what I want. I'm not removing the bellhousings initally.
Old 09-11-2017, 05:09 PM
I hear you, I could shim them yes, my question was has anyone seen the Z type specifically for deep pans. I have to remeasure the depth of the pans, I had a set of stands on my motor last month and they were a good bit shy of the floor. Yes I can mod them-just wanted to see if there were some that existed before necessitating that... The Z type is the design I'd like to use at the moment. I could build my own and get them exactly the way I want them but I have ZERO time for that.
Old 09-11-2017, 05:26 PM
F-2 Speedy's Avatar
then you should of stated that, put a full dressed engine on that pos you posted and see what happens........I built mine with bell housing supports
Old 09-11-2017, 05:55 PM
No need to get huffy, I have put my fully dressed engine carb to pan full of oil with excessories on a set and they were great just not tall enough, hence the initial question. I appreciate your input, I do; but so it goes with most forums and threads people tend to stray off course and neglect the black and white of the question.
Old 09-11-2017, 08:16 PM
Found them, actually from the guy I bought my outdrive jack from. Great price and stout units. Thanks for all that contributed.
Chevy Cradles
