Excessive blowby and oil leaks
I run at Lake Tahoe and my peak oil temp never goes over 195. My water never goes over 120 the water is so cold. I thought the water temp gauge was broke the first few times as it didn't even read.
Too cold a block? If bores don't grow to the correct size, you can get ring and bore wear issues. But I don't think it can happen in 10 hours run time. I think there is a ring and piston not liking each other issue...
I have the Hardin remote bulkhead and I thought that the filter gasket was leaking, and it was until I cranked the filter on extra tight, but the bigger problem was the threads leaking on the fittings and dripping onto the filter lip. I tried everything on the threads including soft sealers, hard sealers, over tightening, under tightening, new fittings, etc. I emailed Hardin with no response. I would've never been able to pin point the source with out an oil dye and black light.
Some repeat here but like icdedppl mentioned ditch the front and rear gaskets. Not sure what gen you have though. I do wonder iff your length Of hoses with a potential breather that may be a little restrictive. I like using the Hardin style breathers. With your cold water temps I see an oil stat in order. I recall your build and I know you were extremely thorough but things do happen. Does it blow your dipstick out. Also do you have a flame arrestor you could try and use some temp hose ty in. Sounds like you have crankcase pressure for sure but if it was just the oil I rember on my 350 truck engine I accidently used an oil plug with the hole in it back on top rear of block behind intake. PITA. Had my pipe plugs mixed up and didn't catch it. Was the same size as the ones behind the timing chan and gear.
For your our sake I hope you don't have to tear it down with such low hours but....
Also you ever experiment with different induction. Just curious...
Yes I did get a cooler with a t stat from the recommendations on this site. I would like to stay NA as I don't have room in the bilge for pulleys. Somone had a 177 on it before and had to drill a whole in the back seat for the pulley and it is little. I have a mark IV block and dipstick is dry and like I stated I had tried a few different evac sysytems from basic K&N breathers to what i have now. Will do a leak down test and see what cylinder or cylinders are having issues. When I had it out the last time I checked all the plugs and cam plug for leaks on the back of the block.
Great to hear you are out and using her!
I too have to run thermostats with the cold temps...
how much HP are you creating?
Windage tray?
Stroke?
its my opinion that you shouldn't vent the gasses to the catch can and then have the fumes accumulate in the bilge.....I really don't think that is USCG approved. Can you then vent the clean air back to the carb or the exhaust?
Windage tray?
Stroke?
rings now have a very specific hone finish they need to seal, sometimes guys just hone one way with xxxx grit and call it a day, but that does not cut it nowdays, you have a ring seal issue and need to start with re-ringing and hone to whatever the ring manu. calls for.
