promaxx 317 heads >
promaxx 317 heads
promaxx 317 heads
Old 10-06-2017, 11:14 PM
  #31
Originally Posted by MILD THUNDER
I'd worry more about timing events, than just the .050 duration numbers. There is no good reason to run a cam that beats the valvetrain up with a S/C combo like that. The added lift , say going from .650 to .700, likely wont change the speedo reading one bit. Screw up the timing events, and that certainly can make a difference. Billy boats made 1150hp with a 540ci and pump gas, with a mild endurance solid roller 636 lift cam. (whipple build).
Simply changing the ICL and ECL can have a much larger effect than a few degrees of duration at .050.
did he post the details on those engines?
hogie roll is offline
Old 10-07-2017, 10:53 AM
  #32
Received 1,492 Likes on 807 Posts
Joe you did exactly what I was thinking if cam was ground on 110 lsa. That's awesome your able to play around with simulator. It can honestly get a build starting out in the right direction rather than complete guess work. Seriously that's pretty cool stufff. Your contributing to the forum is helpful to many I'm certain. I as well as all others appreciate it. I am curious what those custom cams I had from comp would show in comparison but I don't have cam card to give u timing events. They were 244/248-648/648 on a 111. I'm going to try and find cam card but considering for my 548 sc's. They made 621 hp 6k for kreed in the na 496's.
getrdunn is offline
Old 10-07-2017, 05:26 PM
  #33
Thanks John, its all good shop talk.
As for that cam, I'd need the .006/.004 numbers, and the ICL. The ICL and LSA, will dictate what the exhaust timing events are. In otherwords, a 111LSA cam, with a 107 ICL, will have diffent exhaust timing events than a 111LSA with a 110ICL or 109ICL , etc.
MILD THUNDER is offline
