Help with IAC motor on 575sci >
Old 03-25-2018, 11:16 AM
Default Help with IAC motor on 575sci
Can someone tell me what is the difference between the IAC Pt # 805224A03 ($180ea and the # my engines call for)) and 805224A1 (For earlier motors and $100ea) on the 575 SCI? Also I was told if I remove the "A##" from the end of the part # it will cross reference the automotive part # (Standard Motor Parts AC5 at $30). I have the serial #s that call for 2 on each motor so I will need 4 total and I want to replace them all so this cost can equate to $120 vs $720... Thanks for any help!
radrogerb123 is offline
Old 03-25-2018, 11:57 AM
The 805224A1 is just the IAC motor with O-ring
The 805224A03 is the IAC motor with O-ring, screws and gasket
I believe you are correct about the interchangeability of AC5 and the Merc part, but not positive, take the part to the auto parts store and verify
AllDodge is offline
Old 03-25-2018, 12:09 PM
Thanks, This is why I am confussed
This is why I am confused.
Old 03-25-2018, 12:15 PM
Based on this information OM052947 and below use Part # A1 and OM0529748 and up use A03. And Sierra offers an aftermarket part for the A1 but not the A03. Lastly you will see the A1 in my pic shows the gaskets.
Old 03-25-2018, 12:37 PM
Took some more looking but found part of the issue. Appears from the Merc site that there are comments listed stating
Front only S/N 0M52947 and below
Front and Rear S/N 0M52948 and up
So appears you can use the A1 on the front TB only but can use the A03 on the Front and rear depending if your S/N is within range
Going to edit my first pic to not confuse
AllDodge is offline
Old 03-25-2018, 12:43 PM
Yes your correct except note your s/n
AllDodge is offline
Old 03-25-2018, 01:30 PM
It still seems there must be some difference between the two because your reference to the gasket kit is pictured with the A1 part # so it must not be the distinguishing factor between the 2 part #s. Also if it is nothing more than calling for 1 vs 2 then why does Sierra not offer an aftermarket on both displays?
Old 03-25-2018, 01:31 PM
Is it possible I get 2 IAC motors with the A03 Part #?
Old 03-25-2018, 01:51 PM
I would only be guessing, and with a guess I would expect one of two things.
Either the software for the older s/n motors would need an update if the new IAC was used
Or Merc found that the new IAC (A03) works better and in order to change it also needs the new (maybe thicker) gasket
If BAM was open on Sunday with there tech support side I would give them a call.
Are your s/n above or below the cut off?
AllDodge is offline
Old 03-25-2018, 01:52 PM
It does list 2 where the other only listed 1, but don't know
AllDodge is offline
