Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-28-2002, 04:37 PM   #1
tomcat's Avatar
Detonation - what is it, what causes it and what stops it?
This is a subject that I've never been really clear on. What I have read or been told is that detonation is uncontrolled explosion as opposed to a smooth flame front, that it is caused by hot spots in the chamber and/or high intake air temperatures, and that the cure is more cooling, meaning aluminum heads, cooling systems that favour the heads, cold thermostats, and intercoolers if you're supercharged. I hear that retarding ignition timing is a crutch, not necessary when the right setup is used. I'm assuming that changing compression ratio is not an option and that you're already using premium fuel.
What do you guys have to say about this?
tomcat is offline   Reply With Quote
Old 10-28-2002, 04:48 PM   #2
HyperBaja's Avatar
1990 Baja 190 DSR
It is when the mixture predetonates before the piston is near TDC and puches the piston and rod downward. The "pinging" noise is the piston rattling back and forth on the rod.
Im pretty sure the above is correct, as for compression ratio, a quick fix might be to put in thicker gaskets to lower the compression ratio. Now I have a Q, how does Cylinder volume affect the ratio? The carb is still mixing x amout of air with y amount of fuel?
HyperBaja is offline   Reply With Quote
Sponsored Links
Old 10-28-2002, 05:23 PM   #3
1997 23' WPM Cat!!
An engine is making its peak HP when it is on the edge of detonation, which means once and a while detonation occurs. If you run your motor this way you need to view your plugs frequently and stay on top of weather changes or you WILL hole a piston. (if you are lucky)
WETTE VETTE is offline   Reply With Quote
Old 10-28-2002, 06:00 PM   #4
JimV's Avatar
27' Fountain No Step No blower No Bull
Pre ignition is a hot spot somewhere in the combustion chamber caused by a lean condition where an edge glows causing ignition before tdc. When the spark plug fires it may cause a secondary front that collides. Whether the noise is from parts crashing together or the flame fronts I really dont know but there is one hell of a pressure spike capable a lot of damage. It take a a lot of pressure to push a head gasket out, tulip valves, smash bearings, transfer metal from the block to the main caps.
Detonation is caused by hot intake charge, lean condition or to much ignition timing where the charge is superheated and explodes rather than a controlled burn. A few years ago I had the privilege to see some pictures of the combustion process in miliseconds, courtesy Ford Motor Co. You could see the flame front moving across the chamber, pretty cool stuff. Having more quench in the combustion chamber will help. Increasing the octane to slow the burn will also help. It was also explained to me as a chemical reaction bla bla bla.
My two cents.
JimV is offline   Reply With Quote
Old 10-28-2002, 06:25 PM   #5
speel chekk this fokker!
puder's Avatar
27' Scarab
jim taht is sick!!! still have any of those pics that you might be able to post???
Pardon me, while I whip this out!
puder is offline   Reply With Quote
Old 10-28-2002, 07:31 PM   #6
JSV
Thats combustion not conception LOL!
Old 10-28-2002, 07:36 PM   #7
Turbojack's Avatar
2003 Eliminator 30' Daytona
Somewhere in my closet, I have the white paper that wacakasha (spelling??) engine has done on detonation. If I remember correctly it is a about 10+ pages long. Wacakasha is the one & only company that makes the engine that is used to rate octane. The way octane (motor octane) is rated is by changing the compression on this motor & seeing where detonation starts coming in. Back in the 70's when I was tearing up motors more that I cared to I was given this white paper so I could learn the basics. It is very interesting. When I find it I will try to post.
Detonaton is caused by a number of things first thing is
too low octane of fuel,
lean fuel mixture,
high compression (carbon on heads, & pistons). Carbon causes two problems, 1- hghter comprssion, & 2- hot spots.
air charge temp
timing, cam & spark
Sharp edges in compressiion chamber (valve relief on piston, heads that were surfaced, valve relief in block & etc)
Sorry for the ramble, just typing as thoughts come to me.
Turbojack is offline   Reply With Quote
Old 10-28-2002, 07:44 PM   #8
Turbojack's Avatar
This is not what I have at the house but a lot of the same info is in this. Cclick here
Old 10-28-2002, 08:19 PM   #9
Offshoreonly Advertiser
Mbam's Avatar
1972 Cigarette 36 race
I came across this site recently, found it very informative.
http://www.sdsefi.com/meltdown.htm
Marc
www.mercruiserparts.com
www.go-fast.com
and coming soon - www.BamBoatGear.com
Mbam is offline   Reply With Quote
Old 10-28-2002, 08:22 PM   #10
Ted G's Avatar
Neptune 18 CC, 2005 Superboat Y2K
Actually "pinging" and "knocking" are caused by several different things-all of which are scary. The noise comes from: the valves slamming back shut against the seats, the head actually moving away from the block and slapping back down, piston slap, wrist pin noise, and contact between the bearings and the crank as the oil is forced out. Depending on the severity any or all these things can happen.
In answer to your second question, cylinder volume will not affect compression ratio, but combustion chamber volume will. Say a cylinder takes in 100 cc of air/fuel mix on each stroke. If the combustion chamber at TDC is only 10 cc then the engine will have a compression ratio of 10 to 1. It is relatively easy to figure compression by dividing the displacement by the number of cylinders, then divide the combustion chamber volume by the displacement of each cylinder.
www.cbpba.com
Ted G is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
detonation alter ego General Q & A 11 05-10-2004 09:19 AM
Spark plug detonation p4-33 General Q & A 38 08-08-2003 07:55 AM
HP500EFI with premature detonation F1campion General Q & A 14 03-05-2003 09:36 PM
Good article on detonation Intolerant1 General Q & A 5 01-26-2003 03:08 PM
Detonation Problems dirtlawyer General Q & A 21 06-01-2002 09:23 PM
Search Engine Optimization by vBSEO 3.2.0
