Dash Panel Material
#61
Guys,
Recommendations for the oil temp sender unit? I see LOTS of options on Amazon and such. Does it much matter?
Thanks. Brad.
Thanks. Brad.
#63
Be careful with the sending units. I just updated my gauges from the original Livorsi to new Autometers and 2 of the gauges weren't reading correctly. Found out the Autometers needed a specific sending unit for the range on the new gauges as they differed from the originals.
#64
Yup. That's why I'm asking. Just want to get it right the first time.
Thanks. Brad.
#65
Guys,
<Sheepish grin>.......
Speaking of getting it right the first time... Somehow, I got it in my head that I needed a Livorsi gauge. So, I ordered it, and waited. It was shipped today. Opening the box, it immediately didn't look right. So, I crawled up into the boat. The dash cluster is still hanging loose in the dash cavity, so I grabbed one and held it up to the new gage to confirm. Yup. I needed a GAFFRIG.....
New, CORRECT gauge is on order. Hopefully, I will be able to return this Livorsi. If not, it will make its way over to the SwapShop. At the end of the day, I ain't out that much if they won't let me return it and I can't get it sold.
Otherwise....
Project is moving along nicely. I have the new dash panel drawn and had a clear acrylic template laser cut to verify placement of gauges. After a slight adjustment to gauge positioning, I fired off a PO to the sheet metal shop to laser cut one from .080" aluminum.
I've also made a new bezel for the trim tab indicator and had it powder coated. The color couldn't have been a better match.
Thanks. Brad.
Otherwise....
Thanks. Brad.
87MirageIntruder (03-29-2024)
#66
Lavorsi has a 15% restocking fee. Plus you're out the shipping.. If you talk with them they may forgo the restocking fee.
#67
I'd be good with that.
I bought it from Custom Built Motorsports. I've already reached out to them and they are contacting Livorsi to see if they will allow a return. Apparently, Livorsis are "built to order", so are considered "custom", at least to a degree. We'll see. Fingers crossed.
Thanks. Brad.
#68
Guys,
Keeping ahead of things…..
I’m gonna change the oil during this process, since I have to remove the oil filter mount for modification for the sender. I ordered AmsOil 20W50, but, having the 5+qt Jug in my head, I ordered two 1gal jugs, which is obviously only 8qts, and I need 9. Has anybody ever used Lucas oil treatment (or equivalent)? It’s prescribed to substitute one qt with it, so that would make up the difference. Or am I ordering another gallon jug? Were there any benefits or detriments to using these oil treatments in a marine application?
Also, is there any reason to obediently use the Merc filter? Are there better alternatives?
Thanks. Brad.
Thanks. Brad.
#69
Why the 20w50? You spent all that money already. Buy the extra qt.
#70
