BBC 509cid tunnel ram efi build.
#61
The following 2 users liked this post by Rookie:
articfriends (04-29-2024), JaniH (04-28-2024)
#63
Would be awsome to get base tables for ignition and fuel, but at this point i have a long way to tuning 🙂. My ecu does not have the driver for gm style 4pin stepper motor, so i am going to use the bosch 2pin fir 19mm hose.
#64
36-1 Trigger wheel is ready for some paint.
Trying to find cost effective Bbc bracket for crank sensor, cherry Hall sensor.
#65
I Didn't do much with my fuel at idle. I believe I'm around 13.5 AFR target. When warm my IAC runs at about 0-2%. The key is adjust the throttle blades so it does not need to use IAC at idle. (calibrate TPS after adjusting blades) I have my timing at 36° from 0-1000 RPM (target idle 800 RPM) and I allow idle stabilization timing to throw +/-8° timing to catch the engine at in gear transition with the help of the IAC to open +98% if need to stabilize the idle. I also have the IAC set to fast react.
#66
What you think about the valve stem clearances for N/A, closed cooling, is 0.0017" int, 0.002" exh ok?
sutphen 30 (05-04-2024)
the deep (05-04-2024)
#68
Look what just appeared in my Youtube suggestions...
https://www.youtube.com/watch?v=nEoGwr90SPk&t=646s
#70
