aluminum head and head gasket info needed
When running a aluminum head is there a specifc head gasket your suppose to use? A specific material?
Or can I just use the same style( rubber coated steel shim) I used with my iron heads.
Travis
Travis
Ok, had to try out a new icon..........
Every one of the manufacturers of head gaskets has recommedations.
Here's an example:
http://www.rolmfg.com/Technical/Performance/HG_Tech.htm
This is a list of gaskets from ROL
Here's an example:
thanks guys. I didn't research before I posted, but PAW catalog listed most felpro head gaskets. They listed everything I needed to know and said if they worked with aluminum heads.
Thanks again bros
Travis
Thanks again bros
Travis
Originally posted by blue thunder
Sorry traviss... its me muchin off your thread again. is
Are ARP's head bolts ok for reuse? Got a pile of them and don't want to buy new unnecessarily.
BT
BT
FEL-PRO HAS KILLER GASKETS MADE FOR ALUIM HEADS AND IT DOES TAKE A SPECIAL GASKET
BryanTuvell
11-10-2002 10:56 AM
