Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    GLH
    GLH is offline
    Platinum Member Platinum Member GLH's Avatar
    My Boats:
    Azimut 46
    Join Date
    Dec 2002
    Location
    Burlington, VT
    Posts
    15,166
    Removing Old Name from Stern
    I need to get this name of the back of my new boat it is painted over all the finishes and has already started fading and coming off. I did a search here and got Oven Cleaner, Nail polish remover, acetone and the works. Anyone can give me a task sheet to follow and a degree of difficulty for an idiot like me apart from.
    1. Take it to the local goofy fiberglass man to do it.
    2. Pay him for his work.
    I am actually very familiar with #2 on the list and would like to see if I can actually do any form of a task that involves dexterity of any kind.
    Thanks in advance for your help.
    G.L.
    Attached Images Attached Images
  2. #2
    VIP Member VIP Member JaayTeee's Avatar
    My Boats:
    2002 baja 33 o/l 575sci's
    Join Date
    Nov 2002
    Location
    ankeny,ia.
    Posts
    2,956
    I've been told it's " bad luck"
    to rename a boat
  3. #3
    GLH
    GLH is offline
    My Boats:
    Azimut 46
    Join Date
    Dec 2002
    Location
    Burlington, VT
    Posts
    15,166
    I already have the "Offical Denaming Ceremony Process" to follow I just need the chemical process!
  4. #4
    Platinum Member Platinum Member Rookie's Avatar
    My Boats:
    30 Scarab Panther
    Join Date
    Jan 2003
    Location
    Grand Rapids, MI
    Posts
    2,563
    Lightly scrub it with a PLASTIC pot scrubbing pad (propelene pad), or the softest scotch brite pad available, I think white. soaked in acetone (fingernail polish remover). The pad will give it a little abbrasion w/out scratching the gelcoat. Something that you can still buff out the swirl marks later.
    If the acetone doesn't touch it step up to paint thinner. Check first in an inconspicuous spot to see it discolors, but it looks like it is on white.
    Remember to keep a towel handy so you can keep it from running down the boat. You will leave a ghost image of the name, a good rubbing compound, and some elbow grease should remove it.
    just my thoughts Jason
    No matter how pretty she is, there is a guy who is sick of her S#!t
  5. #5
    Big E
    to rename a boat
    My buddy re-named his boat and had nothing but trouble with it, I heard it was bad luck too. I didn't change the name on mine, call me superstitious because I am.
  6. #6
    My Boats:
    1993 PROFILE
    Join Date
    Oct 2002
    Location
    Cape Coral,Fl.
    Posts
    64
    "easy off" oven cleaner
  7. #7
    Charter Member #232 Charter Member Audiofn's Avatar
    My Boats:
    1979 Formula 302, 88 Formula 311, 81 Donzi 18 2+3 with 454
    Join Date
    Oct 2000
    Location
    Manchester, MA USA
    Posts
    18,007
    I am leary of the cemical stuff. I would get 600 grit sand paper on a rubber block and wet sand it off and then buff it out again. This will do two things. One it will get it off. Two it will remove the the raise were the letters were so hopefully IF you are lucky you will no longer be able to see were the letters used to be.
    Jon
    God is my Co-Pilot..... but I hit a mountain and had to eat him.
  8. #8
    GLH
    GLH is offline
    My Boats:
    Azimut 46
    Join Date
    Dec 2002
    Location
    Burlington, VT
    Posts
    15,166
    Thanks for all your help.
    Regarding the "luck" factor I try rely on luck to a minimum but for the skeptics.
    http://www.boatus.com/goodoldboat/naming.htm#denaming
    http://www.boatus.com/news/namegame.htm
  9. #9
    Join Date
    Jan 2001
    Location
    ST. Louis, MO, USA
    Posts
    1,658
    Easy Off oven cleaner. I've done it on 2 boats, no problems.
    Gary
  10. #10
    Baja Bopp
    How long do you leave the oven cleaner on?
    Gene
Similar Threads
  1. stern light
    By mhifko in forum Formula
    Last Post: 10-02-2007, 07:27 PM
  2. Stern Jack help.....
    By bmergner in forum General Q & A
    Last Post: 09-20-2006, 08:06 PM
  3. 3 or 6 on stern
    By thedonz in forum General Boating Discussion
    Last Post: 12-12-2003, 04:03 PM
  4. Stern Jack Yes or No??
    By Whassup in forum General Boating Discussion
    Last Post: 05-27-2002, 07:24 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
OSO Sponsor
OSO Advertisers
OSO Directory
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
