Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 02-23-2003, 06:05 PM   #1
josh
Selecting props for kaama 357
I have an 86' 357 formula w/kaama drives and I am looking for more top end. I believe the props are original kaama 4 blades.
The boat is powered by 454's pushing high 400's for hp.
I've been told by others that this set up should push low
70's but I'm only running low 60's at about 5300rpm. The boat comes out of the hole great weather there is 1 or 10 persons
aboard. Is there anywhere I can send the props to be reworked
for a higher pitch? Or are there any other suggestions on what might make this pig get up and go?
Thanks for any help you can give me.
Old 02-23-2003, 09:32 PM   #2
Rambunctious's Avatar
95 Formula 336 SR1 525SC's
Hi Josh. Rob from holland. I met you at Torch lake sand bar with my 272 black/yellow formula on the week afte labor day.
I have a perfect idea. you trade me your kaama 357 for my 272 and i'll handle the prop problem .
i have been obsessed ever since i saw your boat. trying to find a kaama boat. saw a few 302's but not sure about going to the square windshield.
anyway. it seems there were quite a few gear ratios available for those drives, but the trannys i think are 1.5
one original 302 had 26 pitch 4 blades and would do 70 on gps at 5000 i think. you do have a lot of boat, but depending on your cam, propping up may get you a litttle more speed AND reliability.
sure you don't want to sell.
do you have any pics of the roost behind that beauty?
post this Q on the formula section too. there are quit a few guys with kaamas. look at my string on "who has kaama formulas"
Rambunctious
Rambunctious is offline   Reply With Quote
Sponsored Links
Old 02-24-2003, 05:03 AM   #3
HOUSTONPROP's Avatar
n/a
give me a call and will be glad to try and help/Darin 281-580-7767
HOUSTONPROP is offline   Reply With Quote
Old 02-24-2003, 05:03 AM   #4
n/a
Old 02-25-2003, 06:04 AM   #5
n/a
4 bld props
nice talking with you today, and will be looking for the props. We will get you dialed in .Thanks Darin
Old 02-25-2003, 10:49 AM   #6
ApachePete's Avatar
I doubt that you'll see the 70's with that power.
I had the first 357 with Kaamas. Came with 425's and 3 blade props. Ran mid 60's.
First change was to 4 blade props (not originally available). They were a bit slower, but MUCH smoother.
Then had motors redone by Baker Engineering to 450+. Still never saw 70.
ApachePete is offline   Reply With Quote
Old 02-25-2003, 12:00 PM   #7
X-Rated30's Avatar
1997/2010 Spectre Catamaran w/ twin 250XS Sports
Just remember that if you re-prop, there are people out here who need your old ones!!! What are they??? Mine had 4-b 16.5x25's on it. I broke one and am looking for more.
I don't chase ambulances... I represent the people that make them necessary.
X-Rated30 is offline   Reply With Quote
Old 02-25-2003, 12:00 PM   #8
josh
Thanks For the insight Apache.
I was hoping to see a little better than low 60's. What were you running for pitch on those 4 blades? And where, or who is a person that is experienced with these drive set-ups. So far I've had good luck with KAAMA's and they're easy to work on. I just
need some advice as to what set up works best.
Old 02-25-2003, 12:08 PM   #9
josh
Kaamascarab30,
I'm shooting at the hip, with this reproping idea. I'm getting ahead of myself because I haven't even determined the dimensions of my wheels yet. I have to go out to the garage
and pull them off. I will be sure to list then on this sight if I decide to reprop.
Old 02-25-2003, 12:36 PM   #10
30' Shadow Cat
Hey guys,Fishead here
I have a 32 cat with Kaamas.I have two sets of three bladed props.One 26 and one 29 pitch.I just repowered and will probably be looking for much bigger wheels.I put twin 785hp blower motors in this thing which is about twice the hp as before.Lets keep in touch about the prop thing and maybe we can help each other out.If you want to try any let me know.
Mark
fishead is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
What's a 357 Kaama worth?? PERFECT MIX Formula 42 02-25-2004 08:46 AM
kaama 357 for sale,worth it? JJONES Formula 0 02-23-2004 05:15 PM
Photos of my 357 Kaama doright General Boating Discussion 14 04-21-2003 11:44 AM
Search Engine Optimization by vBSEO 3.2.0
