Drive Oil Change Pump
Who makes a good gear oil hand pump with a decent size reservoir. I'm tired of the plastic Merc thing.
Try Stevens Instrument Company, 111 E Greenwood Avenue
Waukegan, IL_ 60087
phone: (847) 336-9375_, Model S-33 works great. Order connector for Bravo's. Looks like a yard bug sprayer. Stand by when you fill it up ($$$) and make sure the valve cannot be accidently opened or you will fill your trunk instead of your drives. Stevens may have dealer only sale policy. It is well worth the price.
Ed
Waukegan, IL_ 60087
Ed
Thanks,
I'll contact them.
I'll contact them.
When My Plastic Mercruiser Pump Broke,I Adapted The Pump Fitting That Screwed Into The Lower Unit Of My SSM#5's To MyReversible Porta-quick Oil Changer. I First Flush The Pump Of Engine Oil And Use A Clean Container I've Marked To Indicate How Many Quarts Of Lube Is Pumped Into The Lower Unit. I Slowly Turn The Prop Shaft While The Lube Is Going In To Avoid Air Pockets. Just Trying To Help!
