Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 10 of 10
  1. #1
    RLW
    RLW is offline
    ~~~~ Charter Member
    Join Date
    Oct 2000
    Location
    Western New York
    Posts
    1,451
    Mechanical Fuel Pumps
    Anyone using mechanical fuel pumps for blower applications?
    I am presently running an Edelbrock #1712 that pumps 130 gph.
    It would be easier to stay with the mechanical style but am open to suggestions.
    Thanks in advance for any replies.
    Russ
  2. #2
    A-hole with the loud boat Biggus's Avatar
    My Boats:
    02 Cigarette Mystique T/S
    Join Date
    Apr 2001
    Location
    Naples, Maine
    Posts
    5,567
    I`m running the Holley 130 gph mechanical pump. Merc runs a mechanical on the 900SC
    Attached Images Attached Images
  3. #3
    Ginger or Mary Ann? Charter Member US1 Fountain's Avatar
    My Boats:
    1999 32 Fountain Fever, 1995 Baja 29' Cruiser
    Join Date
    Oct 2000
    Posts
    9,985
    I ran the stock Merc mechanical pump on my blower motor. B&M 250, Dominator 1050. Fuel pressure was always great and never dropped off.
    130gpm...tat a hell of alot of fuel. Whats that need for fuel lines, 3" ID?
    GPH fuel pumps
  4. #4
    Toxic FORMULA Platinum Member mopower's Avatar
    My Boats:
    1989 Formula SR-1 272 t/540's
    Join Date
    May 2002
    Location
    pitman nj
    Posts
    4,234
    GPH fuel pumps
    Yeah, that pump could empty my tank in 1 minute Good God it takes 10 minutes to fill ( and not from empty)
    Now think about for a minute...that's over 2 gallons per second
    You can never have too much horsepower or money...It's just hard to have both.
  5. #5
    Registered paradigm shift's Avatar
    My Boats:
    29' Profile-V 1997
    Join Date
    Jun 2002
    Posts
    529
    Yep- 1071 dual carb mechanical pump. Never had a problem.
  6. #6
    VIP Member VIP Member Back4More's Avatar
    My Boats:
    42 Fountain/370 SeaRay
    Join Date
    Feb 2002
    Location
    Lake Michigan
    Posts
    6,397
    Im using the Carter Competition Series pump (PN# M61045) that is rated 172GPH@8psi and requires no regulator.
    The body was also drill and tapped for larger fittings.
    Twin 750's on top 10-71's
    1993 Straight Bottom 42
    Saris Racing 800SC's
    Bmax/-2 IMCO's
    Cryo Gear sets
    IMCO Boxes
    MitcherT
    Livorsi
  7. #7
    My Boats:
    29' Profile-V 1997
    Join Date
    Jun 2002
    Posts
    529
    I have been running a holley or edelbrock but I think I will try this carter next time. I like no regulator on eless ristriction or hose to run! Why the larger fittings? What size do they come with. Found them in summit but no mention of port size.
  8. #8
    My Boats:
    Join Date
    Apr 2001
    Location
    Naples, Maine
    Posts
    5,567
    CP Performance stocks the 172 gph mechanical pump. It has -10AN in let and -8AN outlet and as mentioned,runs 6-8 lbs no regulator required.
    I think they are 170.00 or so
    Kurt.
  9. #9
    bobby daniels
    used mech.pumps on almost everything as long as it has pressure and volume ,,BOTH !
    Stay away from 90 degree fittings as they cut flow in half at the fittings ,
    The set up depends on RPM's as well ,,,6000 and 540 the mech should be fine just rember volume not just pressure
    Holley pressure regulators only have a 130 thou. hole to flow fuel so use a mallory or barry grant and if you can run a return reg . .....line from reg.back to tank this keeps fuel cool and saves pump from dead heading ,its easy with mallory reg.
  10. #10
    My Boats:
    Join Date
    Feb 2002
    Location
    Lake Michigan
    Posts
    6,397
    Bmax/-2 IMCO's
    Cryo Gear sets
    IMCO Boxes
    MitcherT
    Livorsi
Similar Threads
  1. Aftermarket mechanical fuel pumps???
    By bwiencek in forum General Q & A
    Last Post: 08-20-2008, 10:07 AM
  2. Mechanical fuel pumps VS electric
    By Andy in forum General Q & A
    Last Post: 04-01-2008, 04:25 AM
  3. Mechanical Fuel Pumps for 502's
    By mtgbiker in forum General Q & A
    Last Post: 03-21-2005, 08:14 PM
  4. Stock mechanical fuel pumps?
    By THRILLSEEKER in forum General Q & A
    Last Post: 07-14-2003, 08:47 AM
  5. Mechanical Fuel Pumps
    By jagrlg24 in forum General Q & A
    Last Post: 02-11-2002, 06:10 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
