Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 04-29-2003, 02:22 PM   #1
jdnca1's Avatar
28 Daytona
500EFI Rev Limiters
I'm sure there have been threads on this issue, but I am looking for the easiest most cost effective way to increase the rev limiters from 5250 to ~5500 on 2000 500 EFI's. Is it possible to reflash the Ecm or should I just convert to MSD ignition, and what's involved there. My current Motor has the MSD 7 ignition and its a simple turn of a dial. thanks in advance for the suggestions....
jdnca1 is offline   Reply With Quote
Old 04-29-2003, 02:32 PM   #2
blown1500
The only way to change the rpm limit on a 500efi is to reprogram.
If you will have the ECU limiter placed high or removed, you can use your ignition as the limiter-much easier on the motor as the ECU cuts the fuel, not the ignition. There is no way to take out the ECU limiter without having someone reprogram it that I know of. Arizona Speed and Marine can help.
Sponsored Links
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
TB-IV Rev Limiters?? BadDog General Q & A 2 08-28-2007 08:46 AM
Rev Limiters Donzilla General Racing Discussion 1 02-23-2005 10:51 PM
hp500 rev limiters jryan26 General Q & A 4 01-17-2004 12:23 PM
525sc Rev-limiters 34scarab General Q & A 2 01-13-2004 03:29 AM
Rev Limiters again? THRILLSEEKER General Q & A 5 07-09-2002 09:46 PM
Search Engine Optimization by vBSEO 3.2.0
