help...jetting Holly 830 CFM annular carbs
It sounds like you are having a fuel pressure problem with both your motors. I also had the same problem this year and converted back to mechanical fuel pumps that mercury uses on the HP500's. Electric feul pumps have a tendency to push fuel opposed to pulling fuel from the tank like we all think. Install mechanical guages at your carborators and watch your fuel pressures at various speeds, and you usually will see a fluctuation in your pressure. Keith Eckert and Bobby Saccenti helped me solve my problem with my Apache. Please feel free to call me. Little Tommy 1-414-349-8567
Just had a conversation with the guy that put my motors together....he said I should have a minimum of 8.5 power valve with the cams he put in them....he said they might even need a 10.5. I just checked the existing valves in the carbs and they are only 6.5 dunno if thats gonna do the fix or not
Charter Member # 1083
You must be running very high vac. at idle. The power valve should be about 1 1/2 to 2 less than your manifold vacuum at idle now.
I think he's going in the wrong direction but, I learn somthing new every day.:-)
Ask him what the vacuum gage reads.
Bob
Bob
If it's not a thunder run.............than you're just burnen fuel!!!
I'll find out tomorrow. Picked up a vacuum gauge, am putting distributors back in with new composite gears, and carbs back on with jets squared at 86 and 8.5 power valves. Will be checking vacuum thru manifold .....not carb pull off tube. I'm just hoping to solve the problem of the puddling of fuel in the manifolds...I'm sure everything else will fall together if I can at least accomplish that. Thanks for the figure on the recommended numerical relationship of power valve number to Hg....this should be interesting. At least the weather is gonna hold up...(Lake St Clair...Michigan)
Hey Little Tommy...thanks for the offer of assistance. I did'nt wanna bug you till after I make these changes and see which way things go....I'm saving you for the last page of this chronicle in case I need you. I'll watch the pressure gauges closer tomorrow....but as I recall they stayed pretty steady....thanks
