Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 06-05-2003, 10:05 PM   #1
Team Dysfunctional
Hot Boat's Avatar
28 Scarab, Blown 850+ Hp
Roca Speed rails & what it will take to see 80 mph
I am still thinking about getting speed rails. It is about the only thing left I can do to the boat to get more out of it aside from a drive extension and more HP.
Has anyone priced them out. this would be for a 28ft single engine Scarab
The boat is currently doing 74 - 75mph. I haven't dialed it in yet to see if I can get more out of it and the prop still has to labed. But before I send the prop out i am going to try a 1.36 ratio drive. i was told I might get a one or two mph out of it with my application.
anyone have an Idea of what kind of speed gains I could expect with the rails???
If I am currently doing 75 mph is it possible to see 78-80 mph with the 1.36 drive, labed prop, & speed rails????
Hot Boat is offline   Reply With Quote
Old 06-06-2003, 11:43 AM   #2
IRONMAN's Avatar
Pantera 28
I doubt the 1.36 drive will help in your application as it will decrease torque at the propshaft and increase propeller speed so you will need to go down in pitch. A good lab finishing is usually worth a few mph. I have not tried any speed rails, They should work however placement on the strakes is critical and may require moving them a few times to optimize the setup. Good Luck The Ironman.
The Rougher The Better
IRONMAN is offline   Reply With Quote
Sponsored Links
Old 06-06-2003, 12:58 PM   #3
coolrunning racing
mrv8outboard's Avatar
built myself 1994
please provide the following info and maybe i can shed some light on the subject.
engine rpm @ wot
prop pitch
gear ratio
present speed @ wot
see if i can help
mrv8outboard is offline   Reply With Quote
Old 06-06-2003, 03:50 PM   #4
stevejohns
what are speed rails? Is there a website? Anyone use them?
Old 06-06-2003, 04:12 PM   #5
Official OSO boat whore
8' row boat
I don't see any advantage to going to a 1.36 ratio. So long as you are below 32" in pitch a 1.5 ratio will accelerate better.
Cord is offline   Reply With Quote
Old 06-06-2003, 04:24 PM   #6
1988 Checkmate Vision 221
I tried 1:36 gears in my boat, if you are not currently on the rev limiter with the largest pitch prop available, I think that you will be waisting your time.
dckrafft is offline   Reply With Quote
Old 06-07-2003, 12:48 AM   #7
Team Dysfunctional
Hot Boat's Avatar
Thanks guys for your advise . maybe I wont bother with the gear change.
mrv8outboard I am putting the boat back together after loosing a lifter and crashing a valve into the piston. I only ran the boat for 1 hour this season and I haven't gps it yet all I did was run next to my friends Skater and he said I was doing 75 . apter doing a prop calculation it worked out to be with in that range with 10 percent slip. I hope to have the true #'s after this weekend,
What I did see on my short first run was 5400-5000 rpms with a full tank of gas and a bunch a weight in tools that I was carrying with me. the prop is a 25 pitch with a 1.5 ratio . the boat is a 28 Scarab with a pad bottom. I hope this helps, Thanks
Paul
Old 06-07-2003, 01:04 PM   #8
stevejohns
Id still like to know about these rails??
Old 06-07-2003, 09:06 PM   #9
LapseofReason's Avatar
98 NORTECH 5000V
Do a search on OSO about the rails, I asked about them a while back and a lot of people had a lot of bad thing's to say about them.
LapseofReason is offline   Reply With Quote
Old 06-07-2003, 09:54 PM   #10
Hey Paul,
Considering the size/weight of your boat, I think it is running very well. My boat is quite a bit smaller than yours, and I am only able to spin a 25 inch prop to 5300 rpm. If you want, I can bring a radar Saturday so you know for sure.
Dave
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Custom speed rails baronbob General Q & A 6 06-08-2004 09:48 AM
Roca Speed Rail LapseofReason General Boating Discussion 2 03-11-2003 08:34 PM
Boca Speed Rails ??? blown formula General Q & A 7 12-10-2002 11:21 PM
Speed Rails Tom General Boating Discussion 8 12-01-2002 10:19 AM
Roca Speed Rail Dock Holiday Baja 12 11-29-2002 01:31 PM
Search Engine Optimization by vBSEO 3.2.0
