Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 06-21-2003, 09:42 AM   #1
Raypanic's Avatar
Formula 400SS Eliminator 236 Eagle XP
540 STD deck or Tall Deck?
Any real difference in the two. I have two 502's that I was thinking of having changed into 540ci engines. Any problem with doing that or is it a bad thing to do?
Ray
Raypanic is offline   Reply With Quote
Old 06-21-2003, 11:28 AM   #2
bobby daniels
ray we build them both ways 540 short deck ,,250 long rod or 540 tall deck with a slighty better 400 long rod ,,,we get great results wth both
Sponsored Links
Old 06-25-2003, 09:02 PM   #3
IRONMAN's Avatar
Pantera 28
Bobby, if you use a long rod 6.385 will the pin be too far up into the oil ring land on a 9.8 std deck to run a 4.250 stroke? Would I be better with a standard length rod? Thanks Ironman.
The Rougher The Better
IRONMAN is offline   Reply With Quote
Old 06-25-2003, 10:44 PM   #4
Turbojack's Avatar
2003 Eliminator 30' Daytona
Mine is now 4 years old & no problem to date with short deck. I had a height problem & the tall deck would have made me redue the boat engine cover.
Turbojack is offline   Reply With Quote
Old 06-26-2003, 01:23 PM   #5
bobby daniels
sorry it took so long to answer it slipped by ,,,, we use 250 long rods in the 9.800 block and have no trouble ,and at normal 6k and below the standard rod 6.135 is great as well
either is a good combo ,but the longer rod is always recomended ,but barly in this case !!
BE SURE THEY HONE YOUR BLOCK WITH A TOURQE PLATE !!!!!
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
STD bore of a GM tall deck bow tie? Andy General Q & A 7 12-30-2007 04:06 PM
short deck&tall deck cylinder heads? timucin General Q & A 6 02-21-2005 03:02 AM
540 tall deck or standard? Andy Buzz General Q & A 16 08-26-2004 10:54 PM
Search Engine Optimization by vBSEO 3.2.0
