STD bravo and STD alpha are the same crankshaft-to-propshaft height spec.
A bravo offers more drag than an alpha due to its thickness thru the bullet.
A NovaII will have a conservative X from the factory, and I would expect that 2 inches would be do-able with 4-blade Bravo1 props.
The boat will be slower with Bravos than with Alphas (at identical X heights).
Higher X will increase top speed until excess slippage and/or lack of bow-carrying leverage works against it. Planing performance will generally get poorer at higher X dims. Prop selection can offset poor planing performance and slippage issues. All hulls respond differently and X dims and prop selections are as much a matter of preference according to what aspects of performance are important to your friend.
Rotate in or out? In gives more bow lift and pulls the tail down. It also makes it weird when maneuvering around the docks. Out gives more stern lift and makes dockside maneuvering more predictable. As before, prop selection and driver preferences will make this decision. The best part is that it is nothing more than a prop swap on Bravos to try this out.
Bravo1 props have more bow lift. Hydromotive props have more stern lift. He may like Hydros turning in better than bravos turning out or vice versa.
Rules of thumb are all we can give you. Wish we could do more.
I see London, I see France...
