Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 07-10-2003, 01:31 PM   #1
1988 Mach 1
Question mufflers
Look for a pair of mufflers, Clamp on, on tips already thru the tramsom. 4" dia. Want to be full time, no additional parts, just mufflers. Any ideas on a good pair, and a good price?
88 MACH 1 is offline   Reply With Quote
Old 07-11-2003, 07:39 AM   #2
GregP's Avatar
1989 Scorpion 32 CC
Chapest would be the insert type, available from CP performance, Eddie Marine, etc. They also muffle well, but can cost some HP on bigger engines.
I have a set of Gil clamp-on externals (see in pic). Not quite as much muffling, think they were around $800 per pair when I got them several years ago.
-Greg
GregP is offline   Reply With Quote
Sponsored Links
Old 07-11-2003, 05:28 PM   #3
1988 Mach 1
Troutly, I read the sponsors page, no HPI. Do you know there web addy?
Old 07-11-2003, 06:01 PM   #4
Holeshot
Look into Bassett mufflers, they will slip into your 4" hose they are about 8" long and cause almost no power loss, I had slip in type from Rex Marine, lost 200 RPM
Jim
If you are intrested in the Slip in ones you can have them for $40 + shipping
Old 07-11-2003, 06:10 PM   #5
BAD-HABIT's Avatar
1986Thunderbird F3LS
Quote:
Jim
I lost almost 2mph (GPS) going with the slip in's . If you really need some sound reduction they will work but cost you some HP....
BH
BAD-HABIT is offline   Reply With Quote
Old 07-11-2003, 07:34 PM   #6
BAD-HABIT's Avatar
This question has popped up alot lately....I would do a search for silencers and mufflers...I personally use Drew Shotguns..Affordable,Adjustable,High-Quality and GREAT customer service..Do a search their has been lots of threads on them and others...
BH
Old 07-11-2003, 08:29 PM   #7
1997 23' WPM Cat!!
I run the Drew Shotguns and they work great for my application. My exhaust exit under water and the Shotguns nearly silence the exhaust at idle. At cruise and WOT they really don't do much, but they don't hurt performance. They can be adjusted so they reduce noise, but then there is a slight performance loss.
WETTE VETTE is offline   Reply With Quote
Old 07-12-2003, 08:56 AM   #8
32storm's Avatar
Boatless....
The Drew shotguns work great. Simply, reliable, and easy install.
32storm is offline   Reply With Quote
Old 07-12-2003, 07:37 PM   #9
1988 Mach 1
Thanks, Troutly.
Old 07-13-2003, 10:28 PM   #10
mxz800's Avatar
99 checkmate 270 convincor
hey GREGP saw yoiur boat the other day the all white look really looks good!!
Rob
mxz800 is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Mufflers barron Wanted 14 04-30-2008 04:25 PM
?? For A/T about mufflers risky Active Thunder 1 06-13-2007 09:54 AM
mufflers BARCOASTAL General Boating Discussion 14 06-25-2006 05:31 PM
Mufflers hotlavey General Q & A 51 10-29-2004 11:51 AM
Mufflers splashandburn General Q & A 21 04-15-2004 08:10 AM
Search Engine Optimization by vBSEO 3.2.0
