Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-10-2003, 06:56 PM   #1
Velocity 30ft
Extension Boxes??
I have done a bit of reading about them a while ago but never gave it much thought since I had Alphas. I'm up grading to Bravo's and just wonder if the benefits are worth waiting for me to scrounge the money for them and install them all at the same time. I have external steering and tie bars now, is it a big pain in the back side to install extention boxes and what extras are needed? I"m thinking of them because the drives have nose cones already on them and I read they cause tail lift, so will the boxes counter that, or will I not even notice it?
nauticaL ILLUSIONS is offline   Reply With Quote
Old 09-10-2003, 10:12 PM   #2
KAAMA's Avatar
A boat?....What boat??? How about a galvanized warsh tub wit a tornady strapped own da rear!
If you are installing extension boxes the best time to do it is when you are having the transom assemblies installed on the transom and figuring in the extension boxes so that your "X" demensions are correct. It's much easier and wiser to install everything in together than wait to install the boxes later because then you have to re-figure it all out again. If you can afford it, it's MUCH better to install the boxes as you are installing the rest of the transom hardware. You'll need some kind of extension bracket to extend your steering out to reach the drives as well. I went through all of this when I switch from TRS drives to Bravo One equipment on my boat (32' Active Thunder).
Thank God for the U.S. Marines!
Hey, I'm still learning! ;)
KAAMA is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Extension Boxes BlownScarabI Scarab 10 10-09-2007 12:40 AM
Extension boxes LostinBoston General Boating Discussion 0 05-25-2006 06:43 PM
Extension Boxes baja john Baja 11 04-04-2003 07:56 AM
#6 and extension boxes CIGAR General Boating Discussion 11 02-25-2003 06:24 AM
extension boxes ClockworkOrange General Boating Discussion 6 11-30-2002 09:13 AM
Search Engine Optimization by vBSEO 3.2.0
