Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 01-15-2002, 08:13 AM   #1
Tigger's Avatar
21 Scarab
Post #1 drive
can anyone tell me how much hp a #1 drive can handle reliably? buying a 79 century with a blown motor, i need to know where to start, without going over the drives limits...and im sure ill have many more ?'s on the motor issue...later
Tigger is offline   Reply With Quote
Old 01-15-2002, 08:43 AM   #2
sterndrivespec's Avatar
96 profile 37'
Post
260 hp is the most you want to put to that.if you change the gearcase[lower] to an alpha unit it would take 300 if your carefull
sterndrivespec is offline   Reply With Quote
Sponsored Links
Old 01-15-2002, 10:13 AM   #3
BajaRunner's Avatar
I aint got $hit
Post
I would totally agree with that.
BajaRunner is offline   Reply With Quote
Old 01-15-2002, 12:19 PM   #4
HiPerf2000's Avatar
Sonic
Post
A "#1" or a "MR" drive are just older versions of the alpha, and handle 260hp. Like sterndrivespec said the alpha lower will bolt up.
HiPerf2000 is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
86 TRS drive same case as 215E drive? Full Force Drives and Lower Units 3 10-15-2007 08:29 AM
Monitoring drive oil temp prolong drive life? Canada Jeff Drives and Lower Units 10 07-19-2007 03:38 PM
Mds Marine Drive System Outdrive Worth $ Like Trs Tr Surface Drive thayes11 General Q & A 0 10-02-2005 01:36 PM
Drive oil leaking out of water intakes on side of drive Velocity Tom General Boating Discussion 4 07-16-2003 11:13 AM
Will silent choice for bravo drive bolt up to TRS drive?? panteraracin General Q & A 3 02-07-2002 11:36 PM
Search Engine Optimization by vBSEO 3.2.0
