Roller Rocker Upgrade? >
Old 12-17-2003, 08:20 AM
Kokopelli's Avatar
Default Roller Rocker Upgrade?
What all is involved in upgrading Gen5 heads to Crane Gold Roller Rockers? Are ther any clearence issues with the stck merc. valve covers? Should springs be replaced at the same time? Thanks.
Kokopelli is offline
Old 12-17-2003, 10:59 AM
Charter Member #737
KCHOTBOAT's Avatar
You need to grind the oil drips off on the valve covers. You also need to grind one corner of one of the rockers.
KCHOTBOAT is offline
Old 12-17-2003, 11:03 AM
Charter Member #655
dyno's Avatar
I'd change thw springs if there over 200 hrs old...my .02
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 12-17-2003, 01:23 PM
Were doomed!
Wally's Avatar
also depending on how you are doing this....if the exhaust is on the engine then you may have to loosen the exhaust from the block to get at the inside valve cover bolts. Unless you happen to have a realy skinny u-joint socket assembly. The SnapOn one barly worked for me last time out.
-Wally
Wally is offline
Old 12-17-2003, 04:24 PM
traviss's Avatar
If it is gen5 It has non-adjustable valvetrain. To run roller rockers, you need adjustable valvetrain, Crane makes a kit for this (#99152-16), its just a set of rockers studs that have 3/8" bottom thread a 7/16" upper thread so you can run roller rockers. Then you need valve covers. We ordered a set of Eddie marine valve covers, they are nice pieces, tall and angled on one side to clear the exhuast.
Travis
traviss is offline
Old 12-17-2003, 06:14 PM
Ric232
Default Re: Roller Rocker Upgrade?
Why? Do you plan on spinning high RPM's? If not, I've heard there is nothing to be gained (except more valvetrain noise).
Old 12-17-2003, 07:55 PM
Kokopelli's Avatar
I have to pull the heads due to a bad intake on #1 so while I've got them off I'll do some upgrading as I plan on doing a Whipple soon and Dustin suggested it would be a good idea to do the Crane Gold Rockers
Old 12-17-2003, 08:14 PM
I hate the winter!!
Vinny P's Avatar
Since you have the heads off already, I would upgrade to full 7/16" studs. I don't see the advantage of getting 7/16" studs, while having 3/8" screwed into the heads. Get the heads drilled and tapped at the machine shop before re-assembly..
Vinny P is offline
Scarab28Germany
13
02-21-2008 04:53 PM
team Tickfaw
9
03-28-2007 01:59 PM
GNJ
1
10-23-2006 02:07 AM
blue thunder
14
12-07-2003 02:07 PM
voodoo
11
05-20-2002 02:01 PM
Quick Reply: Roller Rocker Upgrade?
