What ratio to get to 1.36???
I have a bravo xz drive with 1.50 gears right now.
What ratio would you use in a Imco lower to get a final ratio of 1.36 with out changing the upper gear set?
The XR 1.5 has upper gears of 19/16 teeth and lower gears of 19/15 teeth. By changing the lower gears you can get the different ratios. New lower gears of 17/15 will give 1.3458 and new lowers of 16/15 will give 1.266.
